PRI remote acces with B cahannel issue
Jan 7th, 2008
hello,
On cisco 3640 RAS I have a channel issue, users are deconneted intempesively.
With the modem debug I have this message:
Jan 7 09:25:15: CSM: MODEM_REPORT rcvd DEV_IDLE for call_id 0x14D, modem
not found due to wrong b channel number or b channel is deallocated
Jan 7 09:25:15: TTY44: DSR was dropped
Jan 7 09:25:15: tty44: Modem: READY->HANGUP
Jan 7 09:25:15: TTY44: dropping DTR, hanging up
Jan 7 09:25:15: Modem 1/11 CSM: (CSM_PROC_IDLE)<--ASYNC_DTR_DOWN
Jan 7 09:25:15: tty44: Modem: HANGUP->IDLE
Jan 7 09:25:16: TTY44: cleanup pending. Delaying DTR
Jan 7 09:25:16: Modem 1/11 Mica: PPP escape_map: Tx map = FFFFFFFF, Rx map
= 0
Jan 7 09:25:16: %LINK-5-CHANGED: Interface Async44, changed state to reset
Is it a configure problème, a hardware or a telecom compagny issue.
thanks for your helps.
Bests regards
Omar
mchin345 Fri, 01/11/2008 - 10:08
  • Silver, 250 points or more
better authenticate the dial-up clients before telnetting the device
oattoumani Mon, 01/14/2008 - 08:02
thanks for your indications,
I have tests to increase the timer (idle-timeout) and it is going better.
bests regards
Omar ATTOUMANI
