VPN Issues
Jan 7th, 2008
I've got a Cisco 1800 ISR with ADvIPServ running 12.4(11) IOS.
The problem im having is with connecting a Remote users (on Windows XP) to the Easy VPN Server on this unit.
I've configured the Ez-VPN Svr with basics and im using the name/groupname for authentication and placing the PSK in the diallin settings.
But im left with MM_NO_STATE with attempted connections.
I've run debug on isakmp and this seems to hint at key problems but i cant see how??
Any help would be appreciated...
dominic.caron Mon, 01/07/2008 - 08:20
This message indicate that your Phase 1 did not complete.
Can you post your output.
JPDisney01 Mon, 01/07/2008 - 08:23
Have attached the file, i understand that this message implies that phase1 has failed, i just cant see why...
JPDisney01 Mon, 01/07/2008 - 08:48
Can you think of anything that could cause this?
dominic.caron Mon, 01/07/2008 - 08:57
Probably something in the crypto isakmp client configuration or in the profiles
Question...do you really need the profiles ?
JPDisney01 Mon, 01/07/2008 - 09:07
This is the first time i've set one of these up and have suffered the SDM initiation ;O) so im guessing these are all things setup by the wizard?
Well there isn't much to configure on the client (MS or Cisco)
dominic.caron Mon, 01/07/2008 - 10:53
There isn't much to configure on the client (MS or Cisco) like you said
You need profile if your have willcard Lan to Lan VPN or DMVPN and/or multiple Ez group.
If you only what to setup the EZvpn, avoid profile.
JPDisney01 Tue, 01/15/2008 - 01:54
Resolved this. AS is oft the case, a simple over sight on my part. Thanks to those that posted a response.
