Expansion Modul 7914 with CCME 4.0?
Answered Question
Jan 7th, 2008
hi,
is it possible to use the Cisco IP Phone 7914 Expansion Modul with CCME 4.0 or can i use it only with CCM?
thx
Correct Answer by Rob Huffman about 9 years 2 months ago
Hi Konrad,
The use of the 7914 with CME has been supported since around CME 3.1 :) Here is the info for CME 4.0;
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cucme/requirements/guide/cme40spc.html
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Mon, 01/07/2008 - 07:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Konrad,
Hope this helps!
Rob
Rob Huffman Wed, 01/09/2008 - 06:30
  • Hall of Fame,
    Founding Member
Hi Konrad,
You are most welcome!
Take care,
Rob
pcameron Wed, 01/09/2008 - 16:02
  • Cisco Employee,
FYI - The 7914 is only supported with the 796X or 797X handsets. You can't use it on the 794X series phones.
