Problem with fxo port on CME router 2811
fxavier.cat
Hey pros,
i have a router 2811 with cue module, and 2 cards FXO (4 ports each)
i have the configuration as follow:
voice-port 0/0/0
connection plar opx 700
caller-id enable
voice-port 0/0/1
caller-id enable
voice-port 0/0/2
caller-id enable
voice-port 0/0/3
caller-id enable
voice-port 0/1/0
caller-id enable
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
caller-id enable
voice-port 0/1/3
caller-id enable
700 is the number of my AA.
Actually i have only 4 lines connected on that.for example :
555-555-xxx1
555-555-xxx2
555-555-xxx3
555-555-xxx4
But it seems i cant pass 4 calls in same time, i hear the busy tone...
please someone can help me
thanks a lot
6 Replies 6
Brandon Buffin
Check the maximum sessions setup for the auto attendant in CUE.
Brandon
ccn application autoattendant
description "autoattendant"
enabled
maxsessions 8
script "aa.aef"
parameter "busOpenPrompt" "AABusinessOpen.wav"
parameter "holidayPrompt" "AAHolidayPrompt.wav"
parameter "busClosedPrompt" "AABusinessClosed.wav"
parameter "allowExternalTransfers" "false"
parameter "MaxRetry" "3"
parameter "operExtn" "1001"
parameter "welcomePrompt" "AAWelcome.wav"
parameter "businessSchedule" "systemschedule"
end application
enabled
maxsessions 8
script "aa.aef"
end application
my maxsessions value is 8.
Do you see any other problems ?
Can you post your config?
Brandon
ok i found my own error... :-P
thanks for help tho
my dial-peer voice x pots was incorrect.
