BSCI and CCIP equipment question
Jan 7th, 2008
I am currently beginning to study for the BSCI and am planning to go down the CCIP route, although I'm planning to get my CCNP as well at some point. I currently have the following equipment, and know that I will need to replace several components, if not all.
1 each: 2610, 2611 and 2520 routers
1 each: 2900XL and 1900 switches
I'm thinking that I will want at least a couple 2950 or 2960 switches, and probably at least one 3550 or 3650 switches. Also, I'm thinking that I will want at least 1 or 2 2800 series routers. Does anyone have some suggestions on what I should start picking up, and what pieces I should get first? I'm thinking that the CCIP route is much more router intensive, so i'll want to focus on the routers first. Thanks.
dbeare Mon, 01/07/2008 - 08:28
I have seen that emulator and would like to still go about purchasing the equipment, or possibly renting time on equipment remotely. Any suggestions on actual equipment?
Danilo Dy Mon, 01/07/2008 - 08:39
  • Blue, 1500 points or more
I suggest the following;
2 x 2800 Series Routers
2 x 2960 Catalyst Switch (EMI)
1 x 3560 Catalyst Switch (EMI)
The above can be use also for CCIE in case you want to go for it in the future.
Dandy
