SDM 404 error
paul_dunlevy
Hi All,
I'm a bit stuck in my ways and generally prefer the CLI, but I've recently decided to explore the SDM. I was quite impressed with it until I managed to break it! I upgraded a router from 12.3 to 12.4 (both advsecurity feature sets) and the SDM is now giving me a 404 error (URL http://x.x.x.x:8080/archive/flash:home/html/home_aux.shtml)
I need to PAT a web server to the interface address, hence the "8080" port for SDM. I've changed that in the config with - "ip http port 8080"
I think the correct files are in flash
1 22971552 Dec 28 2007 15:34:48 +00:00 c2800nm-advsecurityk9-mz.124-18.bin
2 6389760 Jan 3 2008 23:55:54 +00:00 sdm.tar
3 1505280 Jan 4 2008 00:36:24 +00:00 common.tar
4 931840 Jan 4 2008 00:37:18 +00:00 es.tar
5 112640 Jan 4 2008 00:37:44 +00:00 home.tar
6 1038 Jan 4 2008 00:39:34 +00:00 home.shtml
7 793739 Jan 4 2008 00:42:36 +00:00 256MB.sdf
8 527849 Jan 4 2008 00:43:16 +00:00 128MB.sdf
9 2748 Jan 4 2008 00:43:52 +00:00 sdmconfig-2811.cfg
10 1697952 Jan 4 2008 00:45:30 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
11 415956 Jan 4 2008 00:45:58 +00:00 sslclient-win-1.1.4.176.pkg
12 840 Dec 20 2007 19:35:46 +00:00 vlan.dat
I tried to upgrade SDM to 2.5 by tftp'ing the files across but it made no difference. Using the Windows installer doesn't work, it dies tring to RCP the files across.
Does anyone know how SDM works and what sort of things I should look at next?
Paul.
5 Replies 5
paul_dunlevy
I found the problem but I'll leave this here for anyone else who has the same issue.
Installing the SDM locally on the PC and changing the IE advance options to "Allow active content to run
in files on my computer" works.
It still does not work when launched directly from a browser, but that may because I've changed the port number.
Paul.
Hieu Cao
Level 4
Level 4
I've recently upgraded one of my test router 2811 to SDm 2.5 and it worked fine.
You don't actually copy the files over but run the setup.exe and follow the onscreen instruction to complete the upgrade process.
Can you post your router config.
That's the first thing I tried and RCP is failing. To be honest I'm happy with the local install at this point. Thanks for the reply anyway.
dnoc43
I am having the same problem. The setup.exe fails so I installed manually. Using the debug ip html pages command. I noticed
The router that is not working I get:
notice the tar file its trying to open??? home_aux.shtml.tar???
000065: *Jan 13 23:29:36.487 NewYork: HTML: Unable to open file flash:home/html/home_aux.shtml.tar (requesting html/home_aux.shtml).
000066: *Jan 13 23:29:36.491 NewYork: HTML: Unable to open file flash:home/html/home_aux.shtml.tar (requesting html/home_aux.shtml).
On a different router that is working I see that it is opening the correct .tar file. See below.
015491: *Jan 13 22:35:31.666 NewYork: HTML: open tar = flash:home.tar, file = html/home_aux.shtml
015492: *Jan 13 22:35:31.746 NewYork: HTML: open tar = flash:home.tar, file = html/home_aux.shtml
015493: *Jan 13 22:35:31.810 NewYork: HTML: open tar = flash:home.tar, file = html/home_aux.shtml
I am getting the same error now I can't figure it out.
4944: 004939: Dec 20 12:41:56.046 MDT: HTML: Unable to open file flash:home/html/home_aux.shtml.tar (requesting html/home_aux.shtml).
PackerNation#sh running-config
Building configuration...
Current configuration : 8375 bytes
! Last configuration change at 11:03:43 MDT Mon Dec 20 2010
! NVRAM config last updated at 12:43:49 MDT Sat Dec 18 2010
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname ***********
boot-start-marker
boot-end-marker
logging userinfo
logging buffered 51200
logging console critical
enable secret
no aaa new-model
clock timezone MDT -7
clock summer-time MDT date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto removed
dot11 ssid
   vlan 2
   authentication open
   authentication key-management wpa
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address x.x.x.x
ip dhcp pool ccp-pool
   import all
   network x.x.x.x x.x.x.x
   default-router x.x.x.x
   lease infinite
ip dhcp pool ccp-pool1
   dns-server x.x.x.x x.x.x.x
ip cef
no ip bootp server
no ip domain lookup
archive
log config
hidekeys
ip tcp synwait-time 10
bridge irb
interface Null0
no ip unreachables
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
switchport access vlan 2
interface FastEthernet4
description $ETH-WAN$$FW_OUTSIDE$
ip address dhcp client-id FastEthernet4
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
encryption vlan 2 mode ciphers aes-ccm
broadcast-key vlan 2 change 30
ssid
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.2
encapsulation dot1Q 2 native
ip flow ingress
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
ip address x.x.x.x x.x.x.x
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
interface Vlan2
no ip address
bridge-group 1
interface BVI1
description $FW_INSIDE$
ip access-group 102 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip forward-protocol nd
ip flow-top-talkers
top 5
sort-by bytes
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 2
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static udp x.x.x.x 5060 interface FastEthernet4 5060
ip nat inside source static tcp x.x.x.x 8088 interface FastEthernet4 8088
logging trap debugging
logging x.x.x.x
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 remark local
access-list 1 permit x.x.x.x 0.0.0.15
access-list 1 remark Wireless Lan
access-list 1 permit x.x.x.x.0 0.0.0.31
access-list 23 remark CCP_ACL Category=17
access-list 23 permit x.x.x.x
access-list 23 permit x.x.0.0 0.0.0.15
access-list 23 remark Wireless Lan
access-list 23 permit x.x.x.0 0.0.0.31
access-list 100 remark CCP_ACL Category=1
access-list 100 permit tcp x.x.x.0 0.0.0.15 host x.x.x.x eq telnet
access-list 100 permit tcp host x.x.x.x host x.x.x.x eq 22
access-list 100 permit tcp x.x.x.0 0.0.0.15 host x.x.x.x eq 22
access-list 100 permit tcp x.x.x.x 0.0.0.15 host x.x.x.x eq www
access-list 100 permit tcp host x.x.x.x host x.x.x.x eq 443
access-list 100 permit tcp x.x.x.x 0.0.0.15 host x.x.x.x eq 443
access-list 100 permit tcp host x.x.x.x host x.x.x.x eq cmd
access-list 100 permit tcp x.x.x.x 0.0.0.15 host x.x.x.x eq cmd
access-list 100 deny   tcp any host x.x.x.x eq telnet
access-list 100 deny   tcp any host x.x.x.x eq 22
access-list 100 deny   tcp any host x.x.x.x eq www
access-list 100 deny   tcp any host x.x.x.x eq 443
access-list 100 deny   tcp any host x.x.x.x eq cmd
access-list 100 deny   udp any host x.x.x.x eq snmp
access-list 100 permit ip any any
access-list 102 remark CCP_ACL Category=1
access-list 102 permit tcp x.x.x.x 0.0.0.31 host x.x.x.x eq telnet
access-list 102 permit tcp x.x.x.x 0.0.0.31 host x.x.x.x eq 22
access-list 102 permit tcp x.x.x.x 0.0.0.31 host x.x.x.x eq www
access-list 102 permit tcp x.x.x.x 0.0.0.31 host x.x.x.x eq 443
access-list 102 permit tcp x.x.x.x 0.0.0.31 host x.x.x.x eq cmd
access-list 102 deny   tcp any host x.x.x.x eq telnet
access-list 102 deny   tcp any host x.x.x.x eq 22
access-list 102 deny   tcp any host x.x.x.x eq www
access-list 102 deny   tcp any host x.x.x.x eq 443
access-list 102 deny   tcp any host x.x.x.x eq cmd
access-list 102 deny   udp any host x.x.x.x eq snmp
access-list 102 permit ip any any
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner exec
banner login
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
access-class 23 in
access-class 23 out
privilege level 15
login local
transport input telnet ssh
transport output ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
ntp clock-period 17175052
ntp server 207.46.232.182 source FastEthernet4 prefer
webvpn cef
end
all Flash files are here
3  -rwx        1038  Dec 18 2010 19:55:41 -07:00  home.shtml
    4  -rwx        3179  Dec 18 2010 19:55:41 -07:00  sdmconfig-8xx.cfg
    5  -rwx      112640  Dec 18 2010 19:55:46 -07:00  home.tar
    6  -rwx      931840  Dec 18 2010 19:56:27 -07:00  es.tar
    7  -rwx     1505280  Dec 18 2010 19:57:45 -07:00  common.tar
    8  -rwx         660  Dec 13 2010 04:29:06 -07:00  vlan.dat
    9  -rwx     2242560  Dec 18 2010 20:01:05 -07:00  wlanui.tar
I am using the router to study for my CCNA so I just need to get pointed  in the correct direction.
