01-07-2008 09:13 AM - edited 03-03-2019 08:09 PM
This router runs IOS 11.1, see attempt to add route below - it just fails as if the command does not exist:
Router>en
Password:
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#ip route 0.0.0.0 0.0.0.0 Serial0
% Invalid input detected at '^' marker.
Router(config)#
The marker points to the "o" in route
Solved! Go to Solution.
01-07-2008 09:40 AM
Yes, you are in ROMMON. You cannot use "ip routing" there. You need to load to a valid IOS. If you already have the IOS installed, set the registry to boot to it the next time you reload the router. i.e.
Router(boot)(config)#config-register 0x2102
Router(boot)# reload
Dandy
01-07-2008 09:17 AM
Nardus
That is quite strange. It acts as if IP routing were disabled. Can you check and verify whether the router is configured with no ip routing (would be used if someone wanted to configure bridging for example)? If it is then I suggest that you configure ip routing and then attempt to add the static route again.
I would also suggest that you check and verify that the serial 0 interface is configured with a valid IP address.
Rick
01-07-2008 09:28 AM
I trashed the config and used the wizard to configure it from scratch via console. I even tried the write erase and did the config again. Same problem. I was hoping that it was an IOS 11.1 problem with a wierd workaround - give me a moment to comment out any personal info and I will submit the sh runn
01-07-2008 09:36 AM
You will notice that I configured a default-gateway (the closest thing I could find related to routing...):
Router(boot)#sh runn
Building configuration...
Current configuration:
version 11.1
service udp-small-servers
service tcp-small-servers
hostname Router
enable secret !@##$$
enable password pass
interface Ethernet0
ip address 10.0.0.1 255.255.255.0
no ip route-cache
interface Serial0
ip address 192.168.0.2 255.255.255.0
encapsulation ppp
no ip route-cache
no fair-queue
ip default-gateway 192.168.0.1
line con 0
line vty 0
password pass
login
length 25
line vty 1 4
password pass
login
end
01-07-2008 09:40 AM
Dandy
01-07-2008 09:50 AM
Hi Dandy, well spotted. I will need more of an idiot guide here. What is the easiest way to see if I still have an IOS installed? The reload command did not work.
error:
boot: cannot determine first file name on device "flash:"
01-07-2008 09:34 AM
That is pretty strange.
Are you sure you are not in ROMMON? i.e. "Router(boot)(config-if)#"
Because you cannot configure "ip route" there, but you can use "ip default-gateway" to be able to load an IOS thru network.
Dandy
01-07-2008 09:39 AM
Dandy
I believe that you have a very good suggestion - especially given this line from the recent post:
It sure looks like rommon. And that would explain the symptoms.
Rick
01-07-2008 09:40 AM
Thanks Rick.
Dandy
01-07-2008 09:40 AM
Excuse my ignorance...how will I know if I am in ROMMON - how do you quit from it? - I did not use Ctrl Break or anything like that.
Connected the Blue serial console cable, switched on the router and type in en and password to check the config.
This could be the answer - how do I go back to normal mode?
01-07-2008 09:48 AM
Nardus
In general you would know that you were in rommon if the prompt includes the symbols (boot), which is the case in your post.
There are several common reasons why you would be in rommon:
- you did a break during the boot process (which you say you did not do).
- the config register is set to boot into rommon. (if this is the case try the suggestion from Dandy about setting the config register to 0x2102)
- the router has a problem loading the config from flash.
If you would connect to the console, power down the router, and then power up the router and capture all the console messages as the router boots and post that output we might understand better what is going on.
Rick
01-07-2008 09:56 AM
I did do the ctrl break this morning when I had to kill the password. This router was mothballed about 2 years ago and today my 2600 packed up and I need to get a replacement working in a hurry. I only work with these routers when something goes wrong - pretty much self taught... hence the reason that I am not so sharp with the deeper technical stuff. Will capture the boot screens for you - Thanks for the help so far
01-07-2008 09:56 AM
Nardus
Assuming that it is supported on this router I believe that the best way to get a valid IOS into flash is to use the tftpdnld command.
tftpdnld assumes that you have a valid IOS on a tftp server which is reachable from the router. Is this the case? If so, you need to set some variables like address, mask, default gateway, tftpserver address and then tftpdnld will load the IOS into flash.
If tftpdnld is not supported (or does not work) then the alternative is probably to use XMODEM to put the IOS into flash.
Rick
01-07-2008 10:08 AM
This leaves me with a bit of a dilemma, the support and downloads for the 1600 series has been discontinued. Where can I find a valid IOS image file?
01-07-2008 10:04 AM
Hi Rick,
Boot text as requested:
System Bootstrap, Version 11.1(7)AX [kuong (7)AX], EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
Copyright (c) 1994-1996 by cisco Systems, Inc.
C1600 processor with 2048 Kbytes of main memory
program load complete, entry point: 0x4018060, size: 0x1da950
Loading cisco2-C1600 ... [timed out]
boot of "cisco2-C1600" using boot helper "eprom:c1600-boot-r.111-7.AX." failed
error returned: File read failed -- Time out
loadprog: error - on file open
boot: cannot load "cisco2-C1600"ú
boot: cannot determine first file name on device "flash:"ú
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) 1600 Software (C1600-BOOT-R), Version 11.1(7)AX, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
Copyright (c) 1986-1996 by cisco Systems, Inc.
Compiled Fri 18-Oct-96 00:20 by kuong
Image text-base: 0x04018060, data-base: 0x02005000
cisco 1600 (68360) processor (revision C) with 1536K/512K bytes of memory.
Processor board ID 04908727
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
1 Ethernet/IEEE 802.3 interface.
1 Serial(sync/async) network interface.
System/IO memory with parity disabled
8K bytes of non-volatile configuration memory.
4096K bytes of processor board PCMCIA flash (Read/Write)
Press RETURN to get started!
%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state to down
%LINK-3-UPDOWN: Interface Ethernet0, changed state to up
%LINK-3-UPDOWN: Interface Serial0, changed state to down
%SYS-5-CONFIG_I: Configured from memory by console
%SYS-5-RESTART: System restarted
