prompt CUE
Jan 7th, 2008
How I can to change the languaje of CUE?
rob.huffman Mon, 01/07/2008 - 09:26
Hi Ricardo,
Hope all is well with you :)
Here is the related info;
CUE - Adding or Removing Languages
Installing additional languages or removing languages must be done in online mode only. You cannot add or remove languages using the boot helper except when you perform a complete installation of the Cisco Unity Express software.
Installing Additional Languages
The following information is required for installing languages:
URL of the FTP server.
You are limited to 2 concurrent languages with an AIM-CUE module license
You are limited to 5 concurrent languages with an NM-CUE, NM-CUE-EC, or NME-CUE module license
From this good doc (with Step by Step);
Hope this helps!
ricardorojas123 Mon, 01/07/2008 - 10:31
Rob, I have the Cisco unity express version: 2.3.4. And the command "software install add cue-vm-lang-pack.3.0.1.pkg" is not available. The similar command is : UC500-CUE#software install upgrade url ... is the same ?
rob.huffman Tue, 01/08/2008 - 06:24
Hi Ricardo,
Sorry man, I'm just not sure here, and don't want to send you down the wrong path :(
Why don't you post this question in the current "Ask the Expert" event for CME and CUE;
Hope this helps!
