catOS command
Answered Question
hi! how do i enable snmp in a catalyst 6509 L2 switch module? Can it be done on every switch or in the global mode will do? The objective is to enable snmp, so that it can be monitor by a third party network monitoring tool
Correct Answer by David Stanford about 9 years 4 months ago
If you CatOS code supports the option to configure multiple community strings it won't be a problem. However, if the code only supports one string of each type then you are over writing the old string. This may cause problems for the servers using the old string to poll (if they are).
Overall Rating: 5 (2 ratings)
David Stanford Mon, 01/07/2008 - 09:46
  • Cisco Employee,
To enable snmp globally you would use:
set snmp community
Use the set snmp community command to set SNMP communities and associated access types.
set snmp community {read-only | read-write | read-write-all} [community_string]
Syntax Description
read-only
Keyword to assign read-only access to the specified SNMP community.
read-write
Keyword to assign read-write access to the specified SNMP community.
read-write-all
Keyword to assign read-write-all access to the specified SNMP community.
community_string
(Optional) Name of the SNMP community.
Default
The default configuration has the following communities and access types defined:
•public-read-only
•private-read-write
•secret-read-write-all
For traps:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_configuration_example09186a0080094aa1.shtml
Correct Answer
David Stanford Wed, 01/09/2008 - 07:52
  • Cisco Employee,
