Limiting an SSID to specific APs
Jan 7th, 2008
We are converting to an LWAPP wireless network from autonomous.
One building with 16 APs has an SSID that we only want to exist in that building.
How do I restrict an SSID so that it only exists on specific APs?
So far I've not been able to find a way to accomplish this.
Thanks-
Lynne
Overall Rating: 5 (4 ratings)
Rob Huffman Mon, 01/07/2008 - 11:04
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Lynne,
Hope things are going well with you!
This is probably the feature that can help with this requirement;
Have a look at this info;
Enabling WLAN Override
By default, access points transmit all defined WLANs on the controller. However, you can use the WLAN Override option to select which WLANs are transmitted and which ones are not on a per access point basis. For example, you can use WLAN override to control where in the network the guest WLAN is transmitted or you can use it to disable a specific WLAN in a certain area of the network.
From this doc;
http://www.cisco.com/en/US/products/ps6366/products_configuration_guide_chapter09186a008076cbfd.html#wp1114777
Once you create a new WLAN, the WLAN > Edit page for the new WLAN appears. In this page you can define various parameters specific to this WLAN including General Policies, RADIUS Servers, Security Policies, and 802.1x Parameters.
**Check Admin Status under General Policies to enable the WLAN. If you want the AP to broadcast the SSID in its beacon frames, check Broadcast SSID.
Note: You can configure up to sixteen WLANs on the controller. The Cisco WLAN Solution can control up to sixteen WLANs for Lightweight APs. Each WLAN has a separate WLAN ID (1 through 16), a separate WLAN SSID (WLAN name), and can be assigned unique security policies. Lightweight APs broadcast all active Cisco WLAN Solution WLAN SSIDs and enforce the policies that you define for each WLAN.
From this good doc;
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665d18.shtml#c3
Hope this helps!
Rob
lbadman Mon, 01/07/2008 - 12:02
This one has frustrated me as well- seems 100% counter-intuitive to blast all SSIDs by default, then require the manual removal of them with WLAN ovveride- which also requires an AP reboot when first invoked! I have pleaded with anyone at Cisco who will listen to consider modifying this poorly thought-out mechanism- it is very disruptive and with no configuration scheduling available via WCS, it can be hard to even add a new SSID to a small group of controllers as you may have to reboot APs- not prudent on a busy network. Hopefully the WBU developers will look at how this task was done in the pre-LWAPP days and how competitors like Meru and Aruba do it- I know of no other hardware set that is so completely backward and disruptive in this regard.
Lee
lynne.meeks Tue, 01/08/2008 - 05:22
Thanks all-
Yup- this does seem counter-intuitive.
(there are a few things with the whole WCS/controller set up that I find rather odd..)
I somewhat alleviated the pain by only adding the new SSID to one group of controllers; thereby only having to remove it from HALF of the APs instead of all of them...
Thanks everyone - this forum has been so helpful.
Lynne
Rob Huffman Tue, 01/08/2008 - 06:12
  • Hall of Fame,
    Founding Member
Hi Lynne/Lee,
Yes, this is somewhat like the "old" Cable provider "negative billing" ploy, where they added all sorts of new specialty channels and gave them to you automatically (along with the much higher bill$). Then it was up to you to contact the company to have these removed :( (very a#! backwards!)
The most popular way to mitigate this problem of having to access each AP individually is to use WCS Templates for common requirement AP's. This way the WLAN Override function can be applied at the Template level and then pushed out to the group.
http://www.cisco.com/en/US/docs/wireless/wcs/4.0/configuration/guide/wcstemp.html#wp1072198
Take care,
Rob
lynne.meeks Tue, 01/08/2008 - 07:02
We did end up using the Template function, and I am happy to report that it worked like a champ!
Now we are good to go with using the Templates for other functions.
Thanks again-
Lynne
ralphfowler Tue, 01/08/2008 - 10:56
Lee/Lynne
I am not sure if you are here as well, but I am in San Jose at a meeting with the BU Managers this week (VT meeting for Partners).
I will bring this up here because we have the same issue in our outdoor mesh installations in Muni WiFi.
Ralph
Trending Topics - Security & Network
