How to make auto answear with CallManager express?
Jan 7th, 2008
Is there a way to automatically answer calls with CallManager Express for test purposes?
htarra Fri, 01/11/2008 - 10:24
In Cisco Unified CME 4.0 and later versions you can configure lines on specific phones to automatically connect to incoming calls when the headset key is activated. The phone cannot be busy with an active call and the headset key must be engaged to automatically answer calls. Incoming calls are automatically answered one by one on the phone as long as the headset light remains lit. For each ephone, you can specify one or more lines for headset auto-answer. The following link will help you
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeanswr.html#wp1010363
