Restriction table configuration question?
Jan 7th, 2008
I need to restrict transfers to a specific block of numbers in Unity. (example: 832-1000 through 832-1399)These are the only numbers which a caller should be able to transfer to from an auto attendant or voicemail. This does not include numbers which users can configure for notificaiton purposes (outcalling restriction table is used for this I believe). Can someone give me an example or confirm how I would configure this in the outcalling restriction table?
I was thinking:
83210?? yes
83211?? yes
83212?? yes
83213?? yes
* no
Is it that simple? Feedback appreciated as always.
Overall Rating: 5 (1 ratings)
ranpierce Mon, 01/07/2008 - 11:32
  • Silver, 250 points or more
Enter specific numbers or patterns of numbers that can be permitted or restricted. Include external and long-distance access codes. Use digits 0 through 9 and the following special characters:
* to match zero or more digits.
? to match exactly one digit. Each ? serves as a placeholder for one digit.
# to correspond to the # key on the phone.
that looks good, I would test.
rlp
ranpierce Mon, 01/07/2008 - 11:35
you do need any codes that a phone would need to dial out. a Unity port is just like a phone. It has css/partitions also.
rlp
maratimer_2 Mon, 01/07/2008 - 11:39
Thanks for the input, these were the rules which I was following, so looks like the ony way to really confirm is to test! Thanks.
