Configuring Mobile Connect on CUCM6.0(1)
Jan 7th, 2008
Hi I've configured mobile connect on CUCM 6.0(1). Hold and resume features work well but transfer and conference does not
In CUCM traces I can see "SNRD( 0) - wait-MobileInvokeFeatReq: no 2 calls on the line number"
The profile has 2 calls configured with busytrigger = 2.
Call goes out through a IOS H323 2821 Gw on BRI.
Thanks for help
Guy
smalkeric Fri, 01/11/2008 - 10:26
  • Silver, 250 points or more
Do you have Harware DSP placed for conferencing purpose?. Is so How many DSP's are allocated for conferencing?
guy.richard Mon, 01/14/2008 - 00:39
Thank you for your answer.
I did not have any DSP for HW conferencing, only for transcoding. I added them (16 sessions) but the issue is the same and the DSP are not asked.
In the gateway's "debug h245 events" when I dial *81 or *82 or *83 (hold and resume) I can see "h323chan_chn_process_read_socket: fd=4 of type ACCEPTED has data" but not when I dial *84 (transfer) or *85 (conf).
I only use mobile connect and no mobile voice access so I did not configure any DID number nor VXML service. Is it good ? I could not find any gateway config guide on this purpose.
Guy
tony.hanson Mon, 01/14/2008 - 17:39
Guy:
If your only using Moble Connect you do not need to do all that configuration, actually you don't need to do any gateway configuration, just use you existing gateway. I have it working with MGCP.
guy.richard Tue, 01/15/2008 - 01:09
Tony,
In fact I was missing documentation and did not know how to reach middle-call features using mobile connect only.
So now I configured a DID number pointing to the CUCM's "Enterprise Feature Access DN".
And it works fine, I am designing a TCL script to predial #*84# based on the caller-id because the mobile phones are not for the moment smart phones.
Thanks for all
Guy
