01-07-2008 11:40 AM - edited 03-03-2019 08:09 PM
I am setting up a new network. Is NAT configured on the perimeter router, or the ASA5505 firewall?
Thanks.
Solved! Go to Solution.
01-07-2008 12:00 PM
It depends, I usually prefer to do it on the firewall.
01-07-2008 12:14 PM
Depends on the addressing you have been allocated. A typical setup is a service provider controlled router and they then allocate you a block of ip public ip addresses. One of these will be allocated to the inside interface of the SP router and the rest you use on your own devices.
Usually the device you place behind the SP router is a firewall so it is normally done on a firewall.
Jon
01-07-2008 12:00 PM
01-07-2008 12:14 PM
Jon
