01-07-2008 12:22 PM - edited 03-05-2019 08:19 PM
C3750 switch fails post with the following-
Waiting for Stack Master Election (around 30 seconds)...
POST: PortASIC CAM Subsystem Tests : Begin
TCAM (asic:4) walking-one test failed
Write: 80_00000000_01000000-00_00000000_00000000
Read: 80_00000000_01800000-00_00000000_00000000
POST: POST Failed
POST: PortASIC CAM Subsystem Tests : End, Status Failed
POST: CAM test failed
POST Failed: disabling stack links and shutting down SDP
driver class subsystem initialization failed
!!! WARNING: The switch is not usable !!!
Unable to create l2trace server process, socket_open() failed
any informayion on the causes of this?and is their a remedy?
01-07-2008 12:38 PM
andrew
Based on these error messages I would believe that the problem was a hardware error in the switch. I believe that the appropriate thing to do is to open a case with Cisco TAC about this.
Rick
01-11-2008 02:02 AM
Thanks very much,case opened with TAC and all sorted.
04-03-2008 02:59 PM
Hello. I'd like to know what was the reply you had from CISCO and how you solved this issue? By the way I am experiencig the same problem:
TCAM (asic:1) walking-one test failed
Write: 80_00000000_00000000-00_00000000_10000000
Read: 80_FFFFFFFF_00000000-00_00000000_10000000
POST: POST Failed
"Switch is unusable!"
Thanks, Douglas.
