ACS Authentication issues when added to client group
rlortiz
When my remote site customer adds a new device to an existing client group with a large number of devices, RADIUS authentication to that device fails; authentication is successful if moving that device to a smaller client group. Is there a limit in the number of devices that may be included in a client group? If yes, what is the limit, and why is there no warning or error raised by the ACS 4.1 server when adding a device beyond that limit? We did not have this issue in the previous version ACS 3.1 software.
Thanks for any help you can give
Jagdeep Gambhir
Level 10
Level 10
Please check,
ACS---> Network configuration----> NDG (where you have this switch) ----> Edit Properties----> Remove key.
NDG key overwrites aaa client key.
ACS provides the ability to define a key on a Network Device Group (NDG), as well as define a key on an individual NAS within that group. If the key is defined in both places, the NDG key takes precedence over the individual device key.
~JG
Do rate if helps
