24 hour syslog report fails scheduled report after upgrading to LMS 2.6
Jan 7th, 2008
After upgrading to LMS 2.6 my 24 hour syslog report is failing. Subscribe server is working. I can pull the 24 hour report manually just fine. Also, the archive reports is not giving me reports as well. What must I do to get it all working?
Joe Clarke Mon, 01/07/2008 - 15:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I'm not sure I follow. What error are you getting trying to run the 24 hour reports? What do you mean the manual 24 hour report works fine?
dgrier Mon, 01/07/2008 - 15:55
I can run the 24 hour syslog report from the report geneerator page. However the daily 24 hour report run fails. It has been failing since the upgrade and therefore no archive reports are available.
Joe Clarke Mon, 01/07/2008 - 16:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Okay, I think I understand. I think what's happen is some jar file name have changed which is causing the job JVM not to start. Since you don't have any archives anyway, delete the current scheduled job, and schedule a new one. This will recreate the JVM execution string, and should work for you.
