IPIVR 4.5 write file to unc path
Jan 7th, 2008
Is it possible to write a Document using the write document step to a unc path \\Server\share? I can write across the network using a mapped drive, z:\ when i'm logged in. But when I log off of the server the map disconnects.
nilesh_joshi Mon, 01/07/2008 - 22:20
when u map drive \\server\share
just select option reconnect at logon.
may be this helpfull.
I m trying to do same thing writing file on map drive I m able to connect that map path but file is not write over there.
Could u help me how its work or any sample script u have.
Thanks in advance
stdempe Tue, 01/08/2008 - 06:48
when the server is logged off the maped drive is no longer avalable.
nilesh_joshi Tue, 01/08/2008 - 21:02
you can just lock that server dont logged off..
how u write this files of map drive?
