Need command to list currently active WiFi connections
Answered Question
Jan 7th, 2008
I have an 800 series SOHO router with WiFi enabled. I am having a hard time coming up with a simple command that will produce a list of the current/active end-user WiFi connections for a given network SSID.
The query I want to make is "Show me the list of mac addresses and connection type/class/speed for all active connections to the network TESTWIFI".
Could someone help me out with a quick one-liner?
Jason
Correct Answer by ivillegas about 9 years 4 months ago
As far as I know there is no single command that displays all this information. To list the Mac addresses use show dot11 associations . To know the Qos use show class-map.
Overall Rating: 4 (1 ratings)
Correct Answer
ivillegas Fri, 01/11/2008 - 14:33
  • Silver, 250 points or more
jbuberel Fri, 01/11/2008 - 15:13
Thanks for your suggestion - the 'show dot11 associations' command did the trick for me.
Note: This install of IOS apparently does not support the 'show class-map' command.
Jason
Trending Topics - Security & Network
