uc520 not handing DHCP addresses on data wireless VLAN?
Jan 7th, 2008
I have a new UC520 that is not handing out IP addresses via DHCP on the wireless Data VLAN.
DHCP works fine when using one of the physical ports and for wireless phones on the voice VLAN, but just not wireless on the data VLAN.
If I set a static IP address on the correct subnet (192.168.10.0/24), I can use the wireless data VLAN successfully.
I have reloaded the device several times, as well as changed the wireless security settings. I have also removed the DNS settings for the DHCP server thinking that might be the case. Nothing works.
I have searched online but have found nothing as well.
Please assist ASAP.
erikjustinlee Mon, 01/07/2008 - 19:32
You don't have your dns servers in the dhcp pool, but other than that it looks right... hrm... I'm at a lose right now, plus the power is out and I'm in a storm lol. Sorry. So does it just time out when it tries to connect or what?
mrguitar Mon, 01/07/2008 - 22:55
Ahhh...just figured something out...I get connected just fine on an XP host, but not on Vista.
Strange, does anyone know if Vista uses a DHCP protocol variant or does things inherently different than XP?
