dot11 carrier busy command
Jan 7th, 2008
I am getting 100% busy on all channels when running a "dot carrier busy" command on an AP, other APs close by are OK, so I take it there must be a radio fault, is thereany fix for this?
Anonymous (not verified) Fri, 01/11/2008 - 14:37
This might be a fault with Radio. Try to reset the AP and check again. You can also try upgrading the software.
Richard Bradfield Sat, 01/12/2008 - 13:11
reloading the AP made no difference,seems to bea H/W problem, so the APs have been swapped out
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
