Meshing Access Points to a single SSID without WLC.
Jan 7th, 2008
Is there a way i can do this?
I have 3 access points (1131AG and 1242AG) spread out over the floor but i want to also enable fast roaming and some sort of adjacency with secure communications.
Its hard to find anything without getting the WLC involved...
Please help!
Thanks in advance.
openpeak Tue, 01/08/2008 - 09:36
Do you need to make 2 of them mesh with a central? that would be ideal then just set the central as root mode and the other two as non-root mode, set ssid the same on all and you should be good to go. I use the 1252, the benefit being I can dedicate the 5ghz radio to the backhaul link and the 2.4 for clients.
Trending Topics - Security & Network
