Dial-Plan
Jan 7th, 2008
Hi, What is the configuration if I want an outbound calls from ephone-dn 1 to always use port 1/0/8 and what is the command as well if I want to dial internationally by pressing 9 for instance then I will dial 00(intl call) 966(country code) 1(area code) 540893460(number). Thanks
dial-peer voice 100 pots
numbering-type unknown
destination-pattern 05........
no digit-strip
port 1/0/8
ephone-dn 1
number 1000
label Secretary General
description 1000
name Secretary General
hold-alert 30 originator
ephone 2
device-security-mode none
mac-address 001D.A21A.046C
button 1:1
smahbub Fri, 01/11/2008 - 14:39
Use preference command to take the port 1/0/8 as first preference.
