Alternative to Real Time Monitoring Tool
Answered Question
Jan 7th, 2008
We use the Real Time Monitoring Tool (RTMT) to monitor our E1 Circuits (CM 4). We find that RTMT only gives a "used channels" figure for the ENTIRE router, as opposed to a figure for each E1 Circuit.
As an example, suppose we have four 30 channel E1 circuits on a router. RTMT gives us a utilization figure out of 120, instead of giving us four circuit utilization figures, each out of 30.
Is there a way within the RTMT to monitor channel usage on individual E1 circuits? If not, is there another tool (Either free or commercially available) that allows us to monitor individual E1 channel usage?
Correct Answer by msaskin about 9 years 1 month ago
You can get the information in a few ways.
The most inexpensive (free) is going to be to pull the information from the gateway itself via SNMP. The ifTable OID's should have what you want.
Aside from that, there are various 3rd party applications that will let you do this. Personally, I use Prognosis IPTM for my own organization and across all of our client environments.
-matt
Correct Answer by kolkatagtc about 9 years 1 month ago
Cisco has its own software for these purposes which helps for monitoring other than E1 circuits also. Its named as CUOM (Cisco Unified Operations Manager).
Thanks.
Overall Rating: 5 (2 ratings)
Correct Answer
kolkatagtc Mon, 01/07/2008 - 22:33
Thanks.
Correct Answer
msaskin Tue, 01/08/2008 - 08:47
-matt
davidblu Tue, 01/08/2008 - 21:23
Thank you very much folks.
I'll be investigating all three (SNMP, Cisco CUOM and Prognosis IPTM). The screenshots and bio sheets for the Prognosis product look rather promising.
Thanks again.
dgalati000 Wed, 04/30/2008 - 12:38
Can you send me some info on Prognosis? we're looking at Solar Winds also.
