crypto on loopback or wan interface
Jan 7th, 2008
hello,
i have routers terminating vpn on both sides with the loopback ip address as peers.
should i apply the crypto on the loopback interface or on the wan interface?
Thanks.
Overall Rating: 5 (1 ratings)
dominic.caron Tue, 01/08/2008 - 08:42
You apply the crypto map on the wan interface.
Dont forget to identify the loopback interface as the source in you crypto-map
crypto map mapname local-address loopback 0
Please rate helpful post
ajagadee Wed, 01/09/2008 - 09:22
After following the information posted by dominic.caron, make sure that the VPN Devices have routing information for the loopback address. That is IP Connectivity.
Arul
