Multilink problem
Jan 7th, 2008
I am facing a problem with 2 T1's in a multilink bundle.
There are lot of drops if we do a ping to the other side of the multilink. IF we remove one of the links, then the response is fine. The link shows no errors when it is not part of the bundle
and is clean
Is there anything that we need to do for fine tuning the configuration
routers used are 3825 on both the sides and EIGRP is running over the multilink
R1
interface Multilink1
bandwidth 3072
ip address 192.168.107.6 255.255.255.252
keepalive 1
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
interface Serial0/0/0
bandwidth 1536
no ip address
encapsulation ppp
ip route-cache flow
fair-queue
service-module t1 timeslots 1-24
ppp multilink
interface Serial0/1/0
bandwidth 1536
no ip address
encapsulation ppp
ppp multilink
R2
bandwidth 3072
ip address 192.168.107.5 255.255.255.252
ip nat inside
no ip virtual-reassembly
keepalive 1
ppp multilink
bandwidth 1536
no ip address
encapsulation ppp
ip route-cache flow
no ip mroute-cache
load-interval 30
no fair-queue
ppp multilink
bandwidth 1536
no ip address
encapsulation ppp
ppp multilink
Ambi
amolwaghmare Mon, 01/07/2008 - 23:13
Hi Ambi,
First of all you can't check packet drops and path through ping or traceroute in multilink , better use snmp to get idea of utilization and for droping packet please put the output of following commands:
show interface multilink 1, serialXXX, virtual-access
show ppp multilink
RATE THE USEFUL POST
bvsnarayana03 Mon, 01/07/2008 - 23:25
  • Silver, 250 points or more
Is this a newly configured multilink that you are facing problems with, or it was working well & developed problems shortly. Seems to be a link problem only, as config is good.
You may want to test each link one by one, by making it a part of Mu, to see the behaviour. It would bring closer to the assumption of problems in link.
