VG248 Firmware upgrade
j.huizinga Tue, 01/08/2008 - 03:11
You must check your network and maybe FW. I have upgraded several 248 and normally you just FTP to the VG248 and upload the file and do a reboot.
Maybe factory default might help,
Good luck,
Jan
j.huizinga Tue, 01/08/2008 - 03:13
Good luck,
Jan
j.huizinga Tue, 01/08/2008 - 06:07
I was also using the MS client.
Just ftp to the VG248 and give username/password.
Switch to binary and upload the file.
If this doesn't work, you might have a corrupted image.
Good luck
Jan
j.huizinga Tue, 01/08/2008 - 06:30
The VG248 only accepts a passwords, no usernames. Sorry forgot that.
Don't know if it is needed for FTP, but I always set a password. The only thing you must keep in mind is that if you set a password and an enable password, you must use the enable password for FTP.
Can you connect to the VG248 using FTP, does the FTP client tells you that you are logged in?
See further:
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_configuration_guide_chapter09186a0080235151.html#wp1029333
Jan
tboynton Fri, 12/19/2008 - 11:13
I've upgraded many VG248's over that last 4-5 years and have experienced trouble ftping for Windows on various machines. I take the same image and dump it on a Linux machine and ftp and it works perfectly. On the Windows PCs the file transfer aborts half way through. Haven't figured out why. Truthfully, I didn't care because I had a workaround.
