Question on CCDP required exams
Jan 8th, 2008
I am CCNP and CCDA, i took 642-892 during mt CCNP certification.
The Cisco CCDP lists 2 tracks:
Track 1:
642-901 BSCI
642-812 BCMSN
642-873 ARCH
642-871 ARCH
Track 2
642-892 Composite (BSCI, BCMSN)
642-871 ARCH
Does this mean I *must* take 642-871, only because I took the composite 642-892 for my CCNP?
The same page says for track 1the last day to test for 642-871 is 2/23/08?
jamgarci Mon, 01/21/2008 - 17:55
Are you sure about that? If either ARCH exam works with 642-892 then why is only the older one listed? Also 642-871 is not currently listed under "Soon to be Retired Certification Exams".
I am hoping this is a simple error and 642-873 will work with 642-892. It seems it should since it is a newer exam and is designed to replace 642-871.
Can someone verify this for sure?
steven2000 Fri, 01/11/2008 - 01:23
hi jan jong, I'm currently studying for the composite exam 842-892. Any advice or tips on how to prepare for the exam?
I also plan to do CCDP and CCSP before I proceed my my CCIE cert.
Jan Jong Fri, 01/11/2008 - 01:58
Off course first of all read the books to get the knowledge (it's a lot for both BSCI and BCMSN).
Having hands-on experience helps a lot. If you don't have access to devices you could use the dynamips emulator that allows you to run IOS on a PC (see for howto's and example lab setups)
To get a feel for the exam questions with practice exams/braindumps, etc. you can find pointers to a lot of this kind of stuff here
