As to see logs in the 6509
Jan 8th, 2008
I have a 6509 with this features:
IOS (tm) c6sup2_rp Software (c6sup2_rp-JS-M), Version 12.1(27b)E, RELEASE SOFTWARE (fc2)
Technical Support:
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 10-Feb-06 13:25 by hqluong
Image text-base: 0x40008F90, data-base: 0x41B50000
ROM: System Bootstrap, Version 12.1(4r)E, RELEASE SOFTWARE (fc1)
BOOTLDR: c6sup2_rp Software (c6sup2_rp-JS-M), Version 12.1(27b)E, RELEASE SOFTWARE (fc2)
swg-a0-azr uptime is 12 weeks, 2 days, 18 hours, 24 minutes
Time since swg-a0-azr switched to active is 12 weeks, 2 days, 18 hours, 26 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 18:45:16 WET Sat Oct 13 2007
System image file is "sup-bootflash:c6sup12-js-mz.121-27b.E.bin"
cisco WS-C6509 (R7000) processor (revision 3.0) with 112640K/18432K bytes of memory.
Processor board ID TBP06170186
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
60 Virtual Ethernet/IEEE 802.3 interface(s)
18 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x102
Since 10 days, I can't see logs in console. When I make:
#sh loggin
Syslog logging: enabled (240 messages dropped, 2 messages rate-limited, 0 flushes, 0 overruns)
Console logging: level informational, 18808 messages logged
Monitor logging: level debugging, 3777 messages logged
Buffer logging: level debugging, 0 messages logged
Exception Logging: size (4096 bytes)
Trap logging: level notifications, 1766760 message lines logged
Logging to, 1766760 message lines logged
Log Buffer (4096 bytes):
My configuration is:
logging history informational
logging trap notifications
logging source-interface Vlan1
Can anyone help me?
Thanks in advanced.
jose.m.goncalves Tue, 01/08/2008 - 06:26
Hello Davistan
Thanks for your response, but this didn't resolve the problem.
The problem persist.
yjdabear Tue, 01/08/2008 - 10:35
If you're saying you don't see anything with "show logging" on the device, have you configured "logging buffered [buffer size] debugging"? Right now, it shows "Buffer logging: level debugging, 0 messages logged" while "Monitor logging: level debugging, 3777 messages logged".
