1130AG Access Points with WPA2PSK Security - Not working with OS X?
We're working on setting up a wireless network in our building, we're putting in Cisco 1130AG Access Points. Everything's working alright with Windows XP and Vista but we can't get OS X to work. I've read in some forums that a release for 10.4.9 something came out that screwed up these wireless connections. I've also read that there were problems with Apple products and Cisco wireless products that Cisco corrected. Can someone please help me out with what to do to configure the access points or any fixes I should be looking for?
Thanks for your help.
cvislocky Wed, 01/09/2008 - 07:04
Under your WLAN configuration make sure Aironet IE is not enabled.
Thanks for your response. We don't have the Wireless LAN Controller installed and have only configured directly through the AP's, which don't seem to have any configuration changes regarding Aironet IE's. Is there a config change that needs to be made just on the AP's? Or is the Wireless LAN Controller software necessary to make this change?
Thanks again.
