01-08-2008 05:59 AM - edited 03-05-2019 08:20 PM
Dear all,
I'm trying to get wccp working between ca6500 and bluecoat sg-800 but without success till now.
Hereby the debug logs I get from ca6500:
an 8 12:49:20: WCCP-PKT:S00: Sending I_See_You packet to "proxyIP" w/ rcv_id 000000A8
Jan 8 12:49:20: WCCP-EVNT:S00: Here_I_Am packet from "proxyIP" w/bad rcv_id 000000A7
Jan 8 12:49:20: WCCP-PKT:S00: Sending I_See_You packet to "proxyIP" w/ rcv_id 000000A9
Jan 8 12:49:30: WCCP-EVNT:wccp_update_assignment_status: enter
Jan 8 12:49:30: WCCP-EVNT:wccp_update_assignment_status: exit
Jan 8 12:49:30: WCCP-EVNT:wccp_validate_wc_assignments: enter
Jan 8 12:49:30: WCCP-EVNT:wccp_validate_wc_assignments: not mask assignment, exit
Jan 8 12:49:30: WCCP-PKT:S00: Sending I_See_You packet to "proxyIP" w/ rcv_id 000000AA
Jan 8 12:49:30: WCCP-EVNT:S00: Here_I_Am packet from "proxyIP" w/bad rcv_id 000000A9
Jan 8 12:49:30: WCCP-PKT:S00: Sending I_See_You packet to "proxyIP" w/ rcv_id 000000AB
Jan 8 12:49:40: WCCP-EVNT:wccp_update_assignment_status: enter
Jan 8 12:49:40: WCCP-EVNT:wccp_update_assignment_status: exit
Jan 8 12:49:40: WCCP-EVNT:wccp_validate_wc_assignments: enter
Jan 8 12:49:40: WCCP-EVNT:wccp_validate_wc_assignments: not mask assignment, exit
this is the config on bluecoat:
wccp enable
wccp version 2
service-group web-cache
forwarding-type GRE
assignment-type hash
interface 0:0
home-router "router ip"
end
ca6500 config:
ip wccp web-cache
outgoing interface:
ip wccp web-cache redirect out
Thanks for you help.
01-08-2008 04:15 PM
From the debugs, it looks like the switch is angry the WAE doesn't want to do mask assignment, so it is erroring out.
The 6500 only supports mask assignment in hardware, so it is in your best interest to configure your bluecoat for this for the best performance.
I'd imagine the command would be 'assignment-type mask' on the bluecoat, but i'm not sure.
Here is a doc talking about WCCP on the 6k:
01-09-2008 12:53 AM
Thanks a lot,
The solution is indeed 'assignment-type mask'
command on the bluecoat.
Thanks again,
