RMON and ATM circuits
Jan 8th, 2008
I'm trying to setup RMON on an ATM circuit to do the following:
1) To alert the management system when the link utilization reaches 85%
2) To alert the management system when the link utilization drops below the 85% mark
I would prefer to achieve this by specifying a percentage as apposed manually calculating the 85% mark in bits/second as the command can be rolled out to various sites which may have different link speeds.
Does anyone know the following:
1) What mib is required to achieve this?
2) What commands are required to achieve this. (excluding SNMP server commands)
Thanks. EP
David Stanford Tue, 01/08/2008 - 07:28
If your devices supports basic mini rmon you can do something like shown in this link:
However, this will use octets and not actual % values.
If you have a NAM it can be much easier using the graphical interface that comes with it.
If you have CiscoView you could also like at the miniRmon tool
