chrobrie Tue, 01/08/2008 - 09:39
  • Cisco Employee,
I believe this refers to the CLI feature allowing user defined objects (class maps, policy maps etc...) to be referenced and filled in via the TAB key. User defined objects are listed as valid input values to complete CLI commands.
- Chris
Eric Rose Tue, 01/08/2008 - 12:51
  • Cisco Employee,
This completion is also available via the '?'
In the example below - remote-access is the class map and is listed when you type '?'
switch/Admin(config)# class-map type management ?
Please enter the name of the class-map (Max Size - 64)
match-all Logical-AND all match statements under this class-map
match-any Logical-OR all match statements under this class-map
remote_access
switch/Admin(config)# class-map type management r?
remote_access
