LMS 3.0 - Portal Charts
Answered Question
Jan 8th, 2008
When I first installed LMS3.0 , I was able to see pie charts (based on type of devices, IOS etc.) using the "Network" portal. I do not get these anymore. I have not upgraded to 3.01 yet.
Any idea why? (my java versions seem to be correct (1.50_11_b03) as all other apps (CM etc) work well.
My views on the portal page are all still default.
thanks
Correct Answer by Joe Clarke about 9 years 1 month ago
Well, assuming you still have RME installed, click on the '+' (plus) icon in the top right-hand corner of the Portal. You should see RME in the list of portlet providers. Expand the RME section, and click the Add button next to "RME Hardware Summary". You can add as many RME portlets as you want, but the Hardware Summary will give you back your pie chart.
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 01/08/2008 - 13:01
The portlet that produces the pie chart is the RME Hardware Summary portlet. Is that portlet still loaded on the Network View? If so, what are its contents? A screenshot might be helpful here.
srego4 Tue, 01/08/2008 - 13:16
I notice that the RME portlet is missing from the "Network" portal view. I only have the CM and DFM portlets in there. This is porbably why I am not seeing it. Any idea as to how to enable the RME portlet? (The strange part is I have not changed any default settings other than previously I was using local admin and now I am using Tacacs for authentication {with all privs})
Correct Answer
Joe Clarke Tue, 01/08/2008 - 13:23
srego4 Tue, 01/08/2008 - 13:45
great!! thanks j. I kept trying to play witht views and did not see the + sign to add the portlets.
Thanks again.
