RA-VPN and All SA proposals found unacceptable
Jan 8th, 2008
Hi all. I'm at a loss of what I've done to screw up this RA VPN. I had it all configured and working properly, then made some changes via ASDM which seemed to muck everything up.
Anyone willing to take a look at this and see where I screwed up? I left all the config in, including the other tunnel-groups. The one I'm concerned with though is the ipsec-ra tunnel.
I appreciate it, thanks.
Jan 08 08:07:57 [IKEv1]: IP = 64.x.x.x, Connection landed on tunnel_group caleavpn
Jan 08 08:07:57 [IKEv1 DEBUG]: Group = caleavpn, IP = 64.x.x.x, processing IKE SA payload
Jan 08 08:07:57 [IKEv1]: IP = 64.x.x.x, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + NOTIFY (11) + NONE (0) total length : 596
Jan 08 08:07:57 [IKEv1 DEBUG]: Group = caleavpn, IP = 64.x.x.x, All SA proposals found unacceptable
Jan 08 08:07:57 [IKEv1]: IP = 64.x.x.x, All IKE SA proposals found unacceptable!
Jan 08 08:07:57 [IKEv1 DEBUG]: Group = caleavpn, IP = 64.x.x.x, IKE AM Responder FSM error history (struct &0x39f8c00) <state>, <event>: AM_DONE, EV_ERROR-->AM_BLD_MSG2, EV_PROCESS_SA-->AM_BLD_MSG2, EV_GROUP_LOOKUP-->AM_BLD_MSG2, EV_PROCESS_MSG-->AM_BLD_MSG2, EV_CREATE_TMR-->AM_START, EV_RCV_MSG-->AM_START, EV_START_AM-->AM_START, EV_START_AM
Jan 08 08:07:57 [IKEv1 DEBUG]: Group = caleavpn, IP = 64.x.x.x, IKE SA AM:1e56eabb terminating: flags 0x0100c001, refcnt 0, tuncnt 0
Jan 08 08:07:57 [IKEv1 DEBUG]: Group = caleavpn, IP = 64.x.x.x, sending delete/delete with reason message
Jan 08 08:07:57 [IKEv1]: Group = caleavpn, IP = 64.x.x.x, Removing peer from peer table failed, no match!
Jan 08 08:07:57 [IKEv1]: Group = caleavpn, IP = 64.x.x.x, Error: Unable to remove PeerTblEntry
Overall Rating: 5 (1 ratings)
dominic.caron Tue, 01/08/2008 - 08:54
It's in your IKE config...
In asdm, in Remote Access VPN/advanced/ipsec/Ike policies
If I remember correctly, the IPsec vpn client work with md5 and not sha
Please rate helpful post
whanson Wed, 01/09/2008 - 13:01
I don't believe the vpn client can support isakmp policy group 5. You need to add one with group 2. too much cpu churning
