Ping Sweeps to test for packet loss on both router and host ends.
Answered Question
Does anyone know of a simple DOS batch mode or Linux script to ping a specified set of subnets with large numbers of pings? Purpose is to look for link problems not normally detected on the network-side equipment.
Correct Answer by Joe Clarke about 9 years 4 months ago
Something like this would work. This script will ping every address from .1 to .254 on each of the specified subnets. It will send one ping packet to each host:
## BEGIN script
proc pingSweep { } {
set subnet "10.0"
set octets [list 1 2 3 4 5 10 11 12 13 14 15 16 17 18 19 20]
for { set i 0 } { $i < [llength $octets] } { incr i } {
for { set j 1 } { $j < 255 } { incr j } {
set addr "${subnet}.[lindex $octets $i].${j}"
ping $addr repeat 1
pingSweep
## END script
Router#tclsh flash:pingSweep.tcl
This assumes you save this script into the router's flash as pingSweep.tcl. You could also type all of this in once you enter tclsh in IOS.
Overall Rating: 4.7 (4 ratings)
umedryk Mon, 01/14/2008 - 09:48
  • Bronze, 100 points or more
The following example will ping the ip address and will send 10 packets. Like wise specify the ip addresses that needs to be pinged
Router1#tclsh
Router1(tcl)#foreach i {
10.10.10.6
} { ping $i repeat 10 }
Correct Answer
Joe Clarke Mon, 01/14/2008 - 23:03
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
## BEGIN script
set subnet "10.0"
ping $addr repeat 1
pingSweep
## END script
