Force ap to join secondary controller
Jan 8th, 2008
I currently have 2 2106 wlc's.
Each is licensed for 6 access points. Controller 1 is full. Controller 2 has 5/6 aps.
When I add the 12th access point it repeatedly attempts to connect to controller 1. It never tries to connect to controller 2.
In the ap config I have specified the names of the primary and secondary controllers.
Primary - Controller_2
Secondary - Controller_1
Shouldn't this force the ap to attempt to connect to Controller_2?
Overall Rating: 4 (1 ratings)
rob.huffman Tue, 01/08/2008 - 09:55
Hi Adam,
Can you try setting WLC # 2 into "Master Controller" mode?
Hope this helps!
acomiskey Tue, 01/08/2008 - 10:06
Thanks Rob.
Turns out I had to set each controller in the same Mobility Group and add each others MAC/IP addresses into the Mobility Group Members. It now appears to use the primary controller first.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
