MS Workgroup shares over VPN with ASAs
Jan 8th, 2008
I have two small sites, both running MS Windows XP Pro in two workgroups. If I set up a VPN tunnel between two ASAs and host files on all the workstations will I be able to see MS workgroup shares on workstations on the other site? Or is NetBIOS needed to see shares on the other site? What do I need to do to see and use shares at the other remote site?
Thanks in Advance.
bobcal2000 Tue, 01/08/2008 - 12:06
Someone is telling me the authentication will not work through the IPSec VPN tunnel between the two ASAs because authentication can not use NetBIOS over TCP/IP. Is there a document with instructions on doing this?
Again Thanks!
