01-08-2008 10:55 AM - edited 03-15-2019 08:06 AM
I rebuilt a server from a backup, and now when I try to access the Global Directory from the Callmanager Administration webpages, i get this error:
Error
The following error occurred while trying to load the requested page.
Problem in executing fso.OpenTextFile()
If I do this locally (with Remote Desktop or VNC) the Directory displays without problems
Does anyone have a clue?
Best regards,
Ariel
01-14-2008 01:01 PM
Check if the regional settings for language of the workstation and callmanager is same.
03-11-2008 10:50 AM
Actually, the mistake was mine. I forgot to install the corresponding Locale Installer that the server had, when I rebuilt it.
Thanks for the help, anyway!
