BRI to PRI FAX with Faxsoftware
pwenger
Level 3
Level 3
I've got the following ennvironement: Act Faxsoftware<----->Eicon 4 BRI ISDN Card<----->Cisco2851 MGCP- BRI interface<---->same Cisco2851 MGCP- PRI<---->PSTN. We use this scenario just for FAX.
Incoming faxes from PSTN is no problem, but it's not possible to send a fax to the PSTN.
Any idea why??
See below the relevant configuration of the router and a debug isdn q931 output.
ROUTER#sh run
Building configuration...
network-clock-participate slot 1
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
ip cef
no ip domain lookup
isdn switch-type primary-net5
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
voice-card 0
no dspfarm
voice-card 1
no dspfarm
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
translation-rule 1
Rule 1 ^0.% 00
translation-rule 2
Rule 1 7007 061967007
Rule 2 7005 061967005
Rule 3 77106 0619677106
interface Loopback0
ip address 172.24.y.x 255.255.255.255
interface GigabitEthernet0/0
ip address 172.24.a.b 255.255.255.252
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving T302 5000
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn send-alerting
isdn sending-complete
no cdp enable
interface BRI0/1/1
description to_DIVA_SERVER
no ip address
isdn switch-type basic-net3
isdn protocol-emulate network
isdn layer1-emulate network
isdn bind-l3 ccm-manager service mgcp
isdn send-alerting
isdn skipsend-idverify
no clns route-cache
control-plane
voice-port 0/0/0:15
translate calling 1
cptone DE
timeouts interdigit 5
voice-port 0/1/1
translate calling 1
compand-type a-law
cptone DE
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 172.24.4.11
ccm-manager config
mgcp
mgcp call-agent 172.24.4.11 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate call-agent source-ipaddr
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp profile default
dial-peer voice 10 pots
destination-pattern 0T
translate-outgoing calling 2
direct-inward-dial
port 0/0/0:15
dial-peer voice 1 pots
trunkgroup DIVA_SERVER
service mgcpapp
direct-inward-dial
forward-digits all
end
Jan 8 18:46:38.871: ISDN BR0/1/1 Q931: RX <- DISCONNECT pd = 8 callref = 0xDD
Cause i = 0x8090 - Normal call clearing
Jan 8 18:46:38.883: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xC951
Jan 8 18:46:38.883: ISDN BR0/1/1 Q931: TX -> RELEASE pd = 8 callref = 0x5D
Jan 8 18:46:38.899: ISDN BR0/1/1 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xDD
Jan 8 18:46:38.931: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x4951
Jan 8 18:46:38.943: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xC951
Peter
6 Replies 6
pcameron
You must add the network-clock-select e1 0/0/0 command to the config to ensure the DSP's use the clock reference that is derived from the E1 RX bit stream on the E1 interface. This is then used to drive the BRI ports. Without this command, the BRI's will use the internal oscillator and there will likely be clock slips on all of the interfaces, including the E1. This will break fax and modem operation. Do a show controllers e1 and you see clock slips being registered.
The other thing to watch out for is that when a port is under MGCP control, the DSP's are always connected to the actual voice port. These may add delay or degradation to fax/modem calls. If you change to H323 operation, the router is capable of performing a pure TDM connection between the B channels on the PRI and the BRI ports - once the call connects the DSP is removed from the signal path and the B channels are cross connected across the router's TDM backplane. Refer here for more background -
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00804794c6.shtml
Thanks for your answer!
I entered the command network-clock-select e1 0/0/0, but nothing changed. Will I have to reset MGCP?
As I understand you, there is no way with MGCP?
Well, fact is, I don't like to change to h323 as I have to reconfigure the whole system.
Peter
hi
i have to configure a fax server with BRI card on a ISR 3845. I have done the same configuration in MGCP but i can't have my an active layer 2.
Pamela
Hi Pamela
make sure, the command isdn protocol-emulate network is still in the config of the router. After a reboot of CUCM this command is automaticly removed.
The explanation for the reason you find in this conversation . http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=General&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc1ccfa
Peter
Thanks Peter,
But it doesn't change, i still have the same problem. Do you know why the status of the BRI PORT ON CUCM web interface, is " Unregistered"?
this is a show isdn extract :
ISDN BRI0/2/0 interface
******* Network side configuration *******
dsl 8, interface ISDN Switchtype = basic-net3
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 64, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 8 CCBs = 0
The Free Channel Mask: 0x80000003
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 9. Layer 3 output may not apply
Pamela
Thx
Pamela
what do you see with show mgcp status? Check the configuration of the gateway in CUCM(hostname). Check the mgcp configuration of the gateway. Is there a firewall or acl between CUCM and gateway?
Cheers
Peter
