IPv6 With eui-64 over Frame-Relay
Hi Experts!
i have 2 routers connected togather via frame-relay link IPv4 and IPV6.AM OK with ipv4 but not with IPV6.have a look to the config plz:
interface Serial1/0
ip address
ip nat inside
ip virtual-reassembly
encapsulation frame-relay
ipv6 address 2001:ABC:123:36::/64 eui-64
serial restart-delay 0
no dce-terminal-timing-enable
frame-relay map ipv6 2001:ABC:123:36:20F:F7FF:FE68:6470 603
frame-relay map ip 603 broadcast
frame-relay map ipv6 FE80:20F::F7FF:FE68:6470 603 broadcast
no frame-relay inverse-arp
interface Serial1/0
ip address
frame-relay map ipv6 FE80::212:7FFF:FE28:7100 306 broadcast
frame-relay map ip 306
frame-relay map ip 306 broadcast
frame-relay map ipv6 2001:ABC:123:36:212:7FFF:FE28:0 306
1)what this and in wich cases we need it:eui-64
2)what this map mean:frame-relay map ipv6 FE80::212:7FFF:FE28:7100 306 broadcast
from where this coming from:212:7FFF:FE28:0
many 10xs to ur explanations
Overall Rating: 5 (4 ratings)
Edison Ortiz Tue, 01/08/2008 - 12:31
eui-64 will complete the IPv6 addresses with information from the interface MAC Address. Very useful on avoiding duplicate IPv6 addresses in a network as most MAC addresses tend to be unique per interface.
I don't recommend using it on frame-relay interface because of the frame-relay mapping. You need to go into the remote router and type show ipv6 int bri to find the whole MAC address and then use that information in your local router for the mapping. Way too many steps...
On the second question, you need to map the link-local address of the remote router in addition to the IPv6 address for dynamic routing protocols.
On the third question, the :212:7FFF:FE28:0 is the node address, usually derived from the interface MAC address.
hi edison
could you plz configure this via Vlan access-list
VLAN Access Control
Configure an ACL with name “y” to obtain the following requirements:-
- Deny Web Traffic from to Subnet
- Permit Web Traffic from to Subnet
- Permit Any Other ip traffic from your Rack to Subnet
Do not Use deny Statements, use only PERMIT statements.
( is VLAN_200)
royalblues Tue, 01/08/2008 - 12:38
1. Interface identifiers (IDs) in IPv6 addresses are used to identify a unique interface on a link and are sometimes referred to as the "host portion" of the IPv6 address.
For Ethernet, the interface ID is
based on the media access control (MAC) address of the interface, in a format called the extended universal identifier 64-bit (EUI-64) format. The EUI-64 format interface ID is derived from the 48-bit MAC address by inserting the hexadecimal number FFFE between
the organizationally unique identifier (OUI) field (the upper three bytes) and the vendor
code (the lower three bytes) of the MAC address. The U/L bit of the first byte is also inverted
2. Shows the frame-relay map where the IPv6 address FE80::212:7FFF:FE28:7100 is mapped to DLCI 306. Broadcast keyword allows the DLCI to forward broadcast and multicast packets, a necessity when using link state routing protocols like ospf
3. 212:7FFF:FE28:0 -- as in point#1 derived from the mac address and inserting FFFE to get the interface identifier
royalblues Tue, 01/08/2008 - 12:55
Not sure how the vlan acccess-list relates to the above post but i think the below config should work
ip access-list extended VLAN_ACL_drop
permit tcp eq www
ip access-list extended VLAN_ACL_accept
permit tcp eq www
permit ip any
vlan access-map Y 10
match ip address VLAN_ACL_drop
action drop
vlan access-map Y 20
match ip address VLAN_ACL_accept
action forward
vlan filter Y vlan-list
royalblues Wed, 01/09/2008 - 23:14
It is a normal access-list
I used "TCP" and restricted only the www traffic. If you want you can use "ip" instead but this will block all access between the hosts
simaskvilius Tue, 01/08/2008 - 14:17
1) EUI-64 is a method used to automaticlly create unique host portion of IPv6 address (last 64 bits of IPv6 address). EUI-64 takes MAC address from router (Router has additional pool of MAC addresses in case if interface is not Ethernet interface) and inserts FFFE hex value into the middle of the MAC address.
2) It is link-local address (IPv4 has no equivalent to IPv6 link-local address). Link-local addresses always begins with prefix FE80::/10 and ends with EUI-64
3) It is ordinary unicast IPv6 address, 212:7FFF:FE28:0 is formed by EUI-64
