Unable to login into WiSM/WLC
Jan 8th, 2008
Have a WiSM blade with 4.2.61 software and we are unable to login into the GUI. The GUI is using the management interface as the IP address, the IP address is pingable, and we are able to get to the login page of the controller. When we click on login, we do not get an authentication prompt. We currently have another WiSM configured the same way with no issues.
We have tried to regenerate the certificate on the WLC, we have turned off secure web and tried the GUI via http, we have cleared the configuration, and still get the same results.
TAC has recommended the blade be replaced and are expecting it in shortly.
In trying to reproduce this problem, we changed the IP address of the management interface (same subnet) and it caused us not to be able to login. We have regenerated the certificate, cleared the config, tried http only, and no longer can get into the WLC.
pmccubbin Wed, 01/09/2008 - 06:54
Hi Dwaine,
I had the same thing happen twice. We simply kept replacing the cards and we finally received a good one.
Please also keep in mind the Cisco Best Practice for removing a WISM from a chassis.
Remember you must power it down from the command line first with this command:
no power enable module
Just for grins as a final troubleshooting idea you might try the command:
power enable module
on the slot the WISM resides in.
Otherwise, I would send it back if you are confident you are configuring it correctly.
Hope this helps.
Best,
Paul
rduke Wed, 01/09/2008 - 11:26
This may not be the same problem; however, I had one controller that would not let me connect via https. WCS could still talk to the controller. I enabled telnet and https started working. I disabled telnet and https was still working. Rebooting the box would not clear the problem. The problem has not returned. Weird.
Randy
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
