static route
Overall Rating: 5 (3 ratings)
Edison Ortiz Tue, 01/08/2008 - 18:34
Inter-Vlan routing will occur without the need for any static routes on this switch.
If you are referring static routes from another routing device, it depends on what Vlan this routing device will reside.
Devices connected to this switch (like workstations) just need to have the default gateway pointing to their respective Vlan. For instance, on Vlan1 - a workstation would have the default gateway of and if you have a workstation on Vlan 2 with gateway of, they should ping each other.
mahmoodmkl Wed, 01/09/2008 - 10:33
Even if u configure a loopback interface it will be shown as directly connected in the routing table,in that case u dnot need any static route.Just configure the gateway on u r hosts properly as according to u r vlan information.
