CME/UC500 dialing from missed calls
Jan 8th, 2008
Does anyone have any info on how to dial directly from missed calls? The missed calls don't have the prefix 9 so when you attempt to dial directly from the missed calls it won't go through.
Paolo Bevilacqua Wed, 01/09/2008 - 02:23
You need translation-profile and rules.
which type of line do you have? If ISDN it can also recognize international calls and prefix 9011 (I assume you're in N.A.).
bschear Wed, 01/09/2008 - 06:34
Do you mean adding a translation rule something like this?
voice translation-rule 1
rule 1 /^\(..........\)/ /9\1/
Paolo Bevilacqua Wed, 01/09/2008 - 06:38
It's simpler:
rule 1 // /9/
With isdn you discriminate international calls and add appropriate prefix too.
bschear Wed, 01/09/2008 - 06:44
Thank you. I will try that. It is just to FXO ports in this case.
