crash info
Jan 8th, 2008
Hi all,
I try to interpret the output of crash info, some error messages are found, but no information is provided by the output interpreter. Does anyone have experience with this error messages ?
No information on error code EOBC-2-EOBC_JAM
No information on error code C6KPWR-4-UNSUPPORTED
No information on error code OIR-6-INSCARD
No information on error code FABRIC-5-CLEAR_BLOCK
No information on error code DIAG-6-DIAG_OK
No information on error code OIR-6-CONSOLE
No information on error code PFREDUN-6-ACTIVE
No information on error code C6KENV-4-FANHIOUTPUT
No information on error code SYS-3-LOGGER_FLUSHING
No information on error code SYS-3-LOGGER_FLUSHED
No information on error code FABRIC-5-FABRIC_MODULE_ACTIVE
No information on error code C6KPWR-4-PSREDUNDANTBOTHSUPPLY
No information on error code EOBC-0-EOBC_JAM_FATAL
No information on error code C6KPWR-4-PSOK
No information on error code SPANTREE-5-EXTENDED_SYSID
No information on error code DIAG-6-RUN_MINIMUM
No information on error code OIR-6-INSPS
No information on error code SYS-5-RESTART
Regards.
irisrios Mon, 01/14/2008 - 14:44
  • Silver, 250 points or more
Just copy and search the error messages in cisco.com. You get an explanation for all the message in cisco.com. For example C6KENV-4-FANHIOUTPUT is explained as The system has detected that the fan tray is a high-output (version 2) fan tray. The system has updated the cooling capacity for the fan tray.
