backup ACS SE database erro
Jan 8th, 2008
I have backuped database in ACS SE 4.1 but it's erro "Backup failed due to FTP error. The Server returned 550 C:\Documents and Settings\ducnv\Desktop : No such file or directory"
have you got any erro same it?? if had, please help??
thanks
ducnv
Jagdeep Gambhir Wed, 01/09/2008 - 08:15
In the ACS backup settings you have specified the Directory as C:/ACS and error messages
say that "Backup failed due to FTP error.
The Server returned 550 ACS File: The system
cannot find the file specified",
It's not able to find the ACS directory, so please change the Directory in ACS backup setting to just / and that should fix it.
~JG
Do rate helpful posts
ducnv_isphn Wed, 01/09/2008 - 18:20
thanks jgambhir for your reply, I copy Directory on FTP server paste into ACS. If you have done it, can you capture the directory in ACS.
thanks very much
