Downloadable ACL Feature
Answered Question
Jan 9th, 2008
Hi all,
this question is about using an ASA with ACS to utilize downloadable per-user ACLs.
I understand that the user-specific ACL gets downloaded from the ACS, but how can I determine to which interface this ACL is bound ?
Is there a default setting, like: the interface the user is connecting to ?
If so, can it be overridden ?
Thanks in advance,
Oliver
Correct Answer by Jon Marshall about 9 years 1 week ago
Oliver
The acl gets applied to the interface referenced in the following command
aaa authentication include telnet -> inside <- 192.168.3.0 255.255.255.0 0 0 RADIUS
So in the above example the downloadable acl would be applied to the inside interface
aaa authentication include telnet -> outside <- 192.168.3.0 255.255.255.0 0 0 RADIUS
and in this one it would be applied to the outside interface.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 01/09/2008 - 03:47
Oliver
Jon
keller.oliver Wed, 01/09/2008 - 04:14
Jon,
thanks for your fast and accurate reply, it was exactly what I wanted to know.
atb,
Oliver
