traffic across ATM over mPLS
jarvar832004
I have a setup like this CE1->PE1->P1->P2->PE2->CE2. The CE and PE have ATM cards on them and the P routers are interconnected on POS with MPLS enabled on all of them. I am trying to run AToM on the PE. I see that the end to end PVC comes up and icmp works fine, but doesnt seem to pass any traffic.
A PVC if terminated on the PE1 locally from CE1 seems to work but not across the MPLS PE and P.
What could be the problem ?
mheusing
Could you please post the relevant CE and PE configs?
Regards, Martin
interface ATM2/0
no ip address
no atm ilmi-keepalive
end
CPE3700-A#sh run int atm2/0.3
Building configuration...
Current configuration : 137 bytes
interface ATM2/0.3 point-to-point
ip address 97.97.97.2 255.255.255.0
pvc 3/300
oam-pvc manage
encapsulation aal5mux ip
end
This is present in the CE routers and the PE as follows
interface ATM4/0
description To 3700
mtu 1500
no ip address
no atm enable-ilmi-trap
bundle-enable
service-policy input atm-in
service-policy output atm-out
pvc 3/300 l2transport
oam-ac emulation-enable
oam-pvc manage
xconnect 4.4.4.4 333 encapsulation mpls
end
The PE1 is 7200 and PE2 is 7600. Both have the same configuration on the interface
Is there a specific reason not to use "encapsulation aal5snap"? In your setup only IP is allowed. Which traffic is affected? How does your routing across the PVC look like?
Regards, Martin
Hi Martin
There is no specific reason for not using the aal5snap,infact i have tried this too, but the problem remains be it aal5snap or aal5mux ip.
The affected traffic is any tcp traffic, or only the icmp is working.
I dont see any problems in routing as i can see the icmp working fine.
