David Stanford Wed, 01/09/2008 - 06:35
You have a couple of options and both are done under RME - Tools - Syslog - Automated Actions
1) Select the Config Fetch action and disable
2) Select the Config Fetch action and select edit it and remove the fields in under email
dragec Wed, 01/09/2008 - 08:05
hi
1) does not work. It is still e-mail type after disable/enable
2) cannot do it because e-mail addr must be entered
Joe Clarke Wed, 01/09/2008 - 08:47
If you change the type, you cannot change it back easily. This is known bug CSCsl60532. You will need to open a TAC service request to get the workaround instructions.
dragec Wed, 01/09/2008 - 08:49
:-))) great. An can I create new one that would be ok?
Joe Clarke Wed, 01/09/2008 - 09:21
No, you cannot create a new one. The inventory collect and config collection tasks are reserved for the system.
