How to write recorded wav file on map drive
nilesh_joshi
How can I write a wav file on map drive using record node in IPCC
Martin Connolly
Basically, I'd use the Write node to write the document to the network share.
See attached example.
Note that you will already need to have a .wav file of the name specified already there, which this script will overwrite.
